Paul Posted July 27, 2004 Report Posted July 27, 2004 I was wondering how to save a VI without a block diagram, only allowing the user to access the GUI. Quote
Bryan Posted July 27, 2004 Report Posted July 27, 2004 FILE >> SAVE WITH OPTIONS >> CHANGED VIs >> REMOVE DIAGRAMS Make sure you keep a copy with the diagrams, if you don't you won't be able to make changes to it later. Quote
Michael Aivaliotis Posted July 28, 2004 Report Posted July 28, 2004 Hey, you can always add a password. File>>VI Properties then select ->Security Quote
Bryan Posted July 28, 2004 Report Posted July 28, 2004 I would make it a long password too. Not too long ago I was browsing the NI Developer Zone and came across a VI that cracks password protected VIs via the brute force method. The longer the password was, the longer it took. I have a 10 or so character password that I apply to some of my VIs and I didn't have the patience to wait around long enough to see if it could crack them. Quote
Paul Posted July 29, 2004 Author Report Posted July 29, 2004 Would saving without the block diagram prevent the user from accidently/intentionally rearanging the front panel icons, or is there a seperate lock command for those? Quote
Bryan Posted July 29, 2004 Report Posted July 29, 2004 If you go to the very last button to the right on the tool bar, (the one that contains "move forward" "group" "ungroup" etc.) There's a selection called "Lock". Just select all controls that you want to lock in place and go up and select "Lock" and there ya go. Quote
Michael Aivaliotis Posted July 29, 2004 Report Posted July 29, 2004 Would saving without the block diagram prevent the user from accidently/intentionally rearanging the front panel icons, or is there a seperate lock command for those? 1255[/snapback] Actualy, password locking would prevent ANY editing including front panel changes. If you go to the very last button to the right on the tool bar, (the one that contains "move forward" "group" "ungroup" etc.) There's a selection called "Lock". Just select all controls that you want to lock in place and go up and select "Lock" and there ya go. 1258[/snapback] Yes, this is a good option as well. It sounds like you are running LV code on a test system and your operators are aborting the VI or something. When you build your VI, you should design it so it automatically runs on startup and has all the menus and toolbars disabled. If you have to click the RUN button to execute your application then something is wrong. Quote
Bryan Posted July 29, 2004 Report Posted July 29, 2004 Actualy, password locking would prevent ANY editing including front panel changes. Really? I actually didn't know that. I've always done mine like you suggested below: Yes, this is a good option as well. It sounds like you are running LV code on a test system and your operators are aborting the VI or something. When you build your VI, you should design it so it automatically runs on startup and has all the menus and toolbars disabled. If you have to click the RUN button to execute your application then something is wrong. 1259[/snapback] That reassures me that I'm programming wisely. I've never had a whole lot of interaction with other LabVIEW programmers, I've learned all I know right now pretty much on my own and have worked independently with LabVIEW (most places I've worked, I have been the only LabVIEW programmer in my department). It's great to get confirmation from seasoned LabVIEW programmers that I'm going down the right path. Quote
