pgstein104 Posted October 12, 2010 Report Share Posted October 12, 2010 Hi All, I am building an executable that includes two custom llbs that were built. The problem I am having is that when it is built, I get two folders with the llb name filled with all of the vis. Is there anyway to just wrap them into my executable? I would think it is easy, but I can't find a way to do it. Thanks, Paul Quote Link to comment
jgcode Posted October 12, 2010 Report Share Posted October 12, 2010 What version of LabVIEW are you using? As of 2009+ this should not be an issue - as the build structure has changed to avoid name collisions when building. Assuming the 8.x build option is unchecked and same-file-names are namespaced differently. 1 Quote Link to comment
pgstein104 Posted October 12, 2010 Author Report Share Posted October 12, 2010 Unchecking 'Use LabVIEW 8.x file layout' worked for me. Thanks alot! Quote Link to comment
