pgstein104 Posted October 12, 2010 Report Posted October 12, 2010 Hi All, I am building an executable that includes two custom llbs that were built. The problem I am having is that when it is built, I get two folders with the llb name filled with all of the vis. Is there anyway to just wrap them into my executable? I would think it is easy, but I can't find a way to do it. Thanks, Paul Quote
jgcode Posted October 12, 2010 Report Posted October 12, 2010 What version of LabVIEW are you using? As of 2009+ this should not be an issue - as the build structure has changed to avoid name collisions when building. Assuming the 8.x build option is unchecked and same-file-names are namespaced differently. 1 Quote
pgstein104 Posted October 12, 2010 Author Report Posted October 12, 2010 Unchecking 'Use LabVIEW 8.x file layout' worked for me. Thanks alot! Quote
