Setting Access Scope on Polymorphic Instances
crelf
I learned something today. From the LabVIEW help:
Note: You can set individual instances of a polymorphic VI as private and set the primary polymorphic VI as public. The polymorphic VI does not break even though instance VIs are private. Setting instance VIs as private is useful if you want users to access instances only through the polymorphic VI selector, so you can edit instance order without causing user problems.
