viSci Posted December 2, 2010 Report Posted December 2, 2010 For some reason this mechanism is forbidden in LV but seems to be supported in CVI. It appears that you can do an async read on a NSV and specify a callback function which gets invoked when the NSV value changes. Does anyone know if it is possible to wrap this functionality up in a dll that would allow me to specify a NSV by URL and a callback vi to execute. Quote
viSci Posted December 6, 2010 Author Report Posted December 6, 2010 Although not what I was looking for initially, one thing I discovered that is pretty cool is that you can feed DSC NSV value change events (they propagate up to LV as User Events) to a Event Callback node (normally used for activex events) and you can then wire in a static node for any callback vi that will automagically execute when a NSV changes value. The holy grail would be to generate User Events from NSV changes without the DSC. Now that I know it can be done in CVI it should be possible to create this in LV. I am not trying to get out of paying for the DSC (we already have a license) it is just that I believe, as LAVA citizens, we have the unalienable right to be able to access the entire shared variable API with just LV. Quote
