sassos Posted December 21, 2010 Report Posted December 21, 2010 Hi all, I'm trying compiling a VI in Labview 7.1 selecting option "Single target file containing all VIs". The process ends correctly, but when I try to execute the .exe (from runtime folder) it asks me where to find the ReadTreaces(numeric).vi (it is a polymorphic vi). How do I can fix that? Thanks! Quote
jgcode Posted December 22, 2010 Report Posted December 22, 2010 Hey Sassos - is that a DSC vi (I haven't used DSC in 7.1)? I lodged CAR # 243120 for a missing polymorphic in Open Traces.vi. You can read about it here - its the second issue I raised in the thread - about mid-way down. Anyways the workaround was to link the actual VI in the code and remove any calls to the polymorphic VI. Hope that helps? Cheers -JG Quote
sassos Posted December 22, 2010 Author Report Posted December 22, 2010 First of all thanks for the answer! Then, yes, I'm trying to export some data from a Citadel DB and the VI will work on a machine with the labview runtime...and how can I link the VI? I noticed that in the "VI setting" tab (in the Build Application windows) I can find any VI utilized in the top level VI but the Read Traces.vi is absent. Furthermore, if at the end of the building process I run the exe and then insert the missing's VI path, it asks me for other stuff in the historical library... Bye. -sassos. Hey Sassos - is that a DSC vi (I haven't used DSC in 7.1)? I lodged CAR # 243120 for a missing polymorphic in Open Traces.vi. You can read about it here - its the second issue I raised in the thread - about mid-way down. Anyways the workaround was to link the actual VI in the code and remove any calls to the polymorphic VI. Hope that helps? Cheers -JG Quote
jgcode Posted December 22, 2010 Report Posted December 22, 2010 .and how can I link the VI? Hi Sassos I mean that: in your source code, instead of using the Polymorphic VI [i.e. Read Traces.vi], use the Polymorphic Member VI [i.e. Read Traces (numeric).vi] instead. Quote
sassos Posted December 22, 2010 Author Report Posted December 22, 2010 Already done, but trying that I received errors connecting data in input. Hi Sassos I mean that: in your source code, instead of using the Polymorphic VI [i.e. Read Traces.vi], use the Polymorphic Member VI [i.e. Read Traces (numeric).vi] instead. Quote
sassos Posted January 5, 2011 Author Report Posted January 5, 2011 Problem solved. With the DSC Run-Time System on the target PC it works fine. Bye! Quote
