Michael Aivaliotis Posted December 28, 2010 Report Share Posted December 28, 2010 I'm responding to user interface events using an event structure. However, some of those events are coming from a signaling property node. Is there any way from within the event structure to detect the difference between actual user generated events? Quote Link to comment
Grampa_of_Oliva_n_Eden Posted December 28, 2010 Report Share Posted December 28, 2010 I'm responding to user interface events using an event structure. However, some of those events are coming from a signaling property node. Is there any way from within the event structure to detect the difference between actual user generated events? You have probably moved on by now but... I was not able to find anything to distinguish between the two sources. (at first I remebered seeing teh "source" property in am image from Jim's book but it did not distinguish between a human and the value signalling source. Ben Quote Link to comment
viSci Posted December 28, 2010 Report Share Posted December 28, 2010 Could you add the mouse and key down events to the value change event case and then look at the event type. I guess that will not really work, sorry. Quote Link to comment
Jarrod S Posted December 28, 2010 Report Share Posted December 28, 2010 I'm responding to user interface events using an event structure. However, some of those events are coming from a signaling property node. Is there any way from within the event structure to detect the difference between actual user generated events? You can't do this. However, instead of using Value Signaling property nodes you could use User Events. You can even create a User Event that can be registered in the exact same event case as a Value Change event. The trick is to make the User Event data be a cluster with the exact same event data from the original event type. Then, the Source terminal on the event structure could be used to tell if it was a UI event or User Event. Attached is an example (LV2010). More importantly, though, why do you want to know the difference? User Event Overloads.vi 1 Quote Link to comment
