Is this bad? Using single element queue to ref object instance
Hello there everyone,
I fear this is a newbie-to-oop question but if you can spare me a minute it would be much appreciated.
Is it okay/good/bad to use a single-element-queue to contain an instance of a class object? And to use this to allow two bits of my application to set&get various class properties.
I have a daqSettings class which lists currently used channels. I have a separate front panel (part of a windowManager class) which allows the user to change channel settings. This window needs to initialise itself with the current channel settings and then set the updated settings for the daq class to use.
Thank you for any advice you can spare.
Regards,
Martin
One of the best reasons to use them within a DVR is to take advantage of the new ability to create your own property node calls off of an object.
Another terrific reason to use them is that if you choose this design choice, you can take advantage of some awesome design that has been developed to aid in the management and extensibility of them
http://decibel.ni.co.../docs/DOC-12813
This tool gives you the ability to have Named DVR's and also adds extensibility to the first obtain and the last release.
The naming of a DVR is a major reason some people would stay with SEQ (Single Element Q), but with the ESF, that is no longer a limitation for DVR's
Add on top of that the ability to have 'first obtain' and 'Last Release' code seamlessly integrated into the flow w/ no additional wires needed...... you can't go wrong
I look forward to seeing your thoughts on the ESF - Extensible Session Framework
Norm Kirchner
~,~ The Captain was Here
PS if you need a good idea of a 'Hello world' style example with it, make a basic timer.
As a programming practice I don't think there's anything wrong with it.
The DVR and the SEQ are essentially equivalent. As Felix said, the DVR is usually favored over the SEQ, but there are advantages to the SEQ. For example, when you lock a DVR using the IPE, the nature of the IPE requires the DVR to be unlocked before exiting that vi. With a SEQ you can lock (dequeue) access, do whatever you want (including exiting the vi,) and unlock (enqueue) access when you're ready. There are ways to work around this by implementing lock/unlock methods in the class that uses the DVR, but it is easier to create arbitrary locking/unlocking scenarios with a SEQ than with a DVR.
Which one you decide to use should depend more on the structure of your application than a desire for source code purity.
