UnderDog Posted January 7, 2011 Report Posted January 7, 2011 (edited) Both the NI-9229 and NI9239 will not allow for " 1 Sample (on demand) " Acquisition mode in LabView Signal Express 2009. Any help will be greatly appreciated. Thanks, rkp Edited January 7, 2011 by rkp Quote
SuperS_5 Posted January 8, 2011 Report Posted January 8, 2011 Hi, This is the error from Signal Express: Error -200077 occurred at DAQ AssistantPossible Reason(s): Requested value is not a supported value for this property. Property: SampTimingType You Have Requested: On Demand You Can Select: Sample Clock Device: cDAQ12 You cannot use this device in this configuration. In LabVIEW you can use the "Set Clock" vi to use something like the "OnboardClock." Although I guess this is not true "Sample on demand", however, the "Get 1 Sample" function gets only the last value. (So it looks like on demand sampling) Quote
