How to change text in text control in program
baril
Hi, I just want to know how to delete the text inside a string control after you press a button. And what finger print scanner or bar code scanner that can interface with LabView?
Please give me a link...
Thanks in advance
You can use a property node or local variable to change the value of a control. There are many resources available for this. Any bar-code reader that outputs text, like a keyboard will work without any trouble. Other bar-code readers may require interfacing with a dll, which is an advanced topic and makes life difficult.
