Triggering problem
ccmf.sun
Dear all,
To begin, I give you the hardware I have :
PXI 1044
PXI 8106
PXI 5142 (Digitizer)
PXI 5441 (AWG)
I use the serial port to send commands to external hardware. In the same time I have to generate a signal with the AWG and to run an acquisition on the digitizer.
My problem is to send a trigger signal to these two hardware when I send the write command on the serial port.
Is it possible to send this kind of signal from the controller on RTSi lines?
Best regards, Fabrice.
PS: sorry for my english.
  • 3 weeks later...
I solved my problem in making a hardware to extract the signal from theRS232 and export it to the trigger entries
of the digitizer and of the AWG.
Dear all,
PXI 1044
PXI 8106
PXI 5441 (AWG)
