Madhav Posted January 17, 2011 Report Share Posted January 17, 2011 i wish to access the XML get one field ( data Size ) from it and adjust the size on the UI so tat the user can enter only specified size of data....... Orelse atleast is there a way to chnage the size of array by my own (Without fetching it frm XML) according to the message selected from UI (i know the size ) but still i want to use xml to automate it Quote Link to comment
Ton Plomp Posted January 17, 2011 Report Share Posted January 17, 2011 Could you make your question a little bit more clear? I don't really understand what you mean with XML and automation. And how this matches with front panel configuration. Ton Quote Link to comment
