Making a mouse driver using Labview
curiouspuya
  On 1/28/2011 at 3:09 AM, curiouspuya said:
Does anyone know how to make a driver for such a device using LV only?
Assuming you mean a traditional Windows driver, you can't.
You'll nee to use the Windows Device Development Kit and it uses some version of Visual Studio and write it C or C++, I forget which.
On the other hand, if you make it with a USB interface and HID compliant you won't need to make a device driver. Windows (and just about every other modern OS) will recognize it and use a built in driver for it.
There are many microcontroller products/projects out there that ship with a USB interface and HID compliant stack.
You can't exactly create a LV driver, but you can use NI-VISA as the driver for a USB device, and then use VISA functions in LV to send USB-RAW communication to the endpoints. This would allow (very) low-level control of the device from LV, even though LV isn't technically the driver.
Search VISA and USB-RAW for more info or see here or here to start.
Thanks. That would mean I would have to first program the output of the device according to some mouse standards for generic USB interface.
Thanks for that Jarrod
