Problems with buttons
I want to write something in the string fields "write buffer" and "read buffer". On the right site the chosen COM is displayed, if the connection is OK it will sent the string (write buffer) over the port and display it in read buffer. If I choose a second connection above I will switch with "next" and there should be the same field where I can write in a string (write buffer) . :lightbulb:
