enable disable options
drycsr
in the attached picture, button #1 is on the stop button and under the array. how to fix this error? the block diagram is also added.
and there are more than one buttons. how to make when a button (button #1) which is clicked by mouse is active, the other buttons are passive?
post-20223-0-67057100-1297084224_thumb.j
post-20223-0-12175200-1297084274_thumb.j
You can reoder the buttons by using the reorder tool on right side of the toolbar (it's cut in half in your image).
When you have an event structure, you can lock the front-panel during the handling of the event. You can also set the 'disabled' state of a control.
Ton
Thanks for your help Ton.
Ton
