sending data from numeric indicators
I want send the number what the user can enter in the given numeric textbox. Each numeric textbox having one command code in hex(example Frequency-0x95). So, if the user enter any value then command will take the value to the SMPS on Slave side, there it will match the code in that and it set the value to SMPS. IF user enter any of the given text boxes and he pressed send button then it has to send the entered values as well if the user click erase then textboes should clear automaticlly. Find the attchment below.
Need big help from you, Please help me.
rajvi.vi
