html in Labview clearing browing data
Hi friends,
I am developing a LV application where I load webpages in Labview and I test the LED/Slider bars of the webpages. I can change the values of LEDs and other indicators thru' a simulator.
But the changes are not reflected in the webpage because my Labview browser is loading the previous page(from memory..?!). I tried 'Refresh' invoke property- didn't work.
Is there a way to clear memory and load the webpages?
post-16569-0-20863100-1298528149_thumb.j
Thanks,
Sharon
You can append a random variable to the URL. But first a quick primer on URLs:
  • "http://" is the protocol
  • "www.example.com" is the host name (the computer the web page is on)
  • "/some/place.html" is the path
  • "?random=SomeRandomValue" is the query string
The query string is a question mark (?) followed by a set of "variable=value"s, separated by ampersands (&). So if your URL is http://www.a.com/b.html you could make it http://www.a.com/b.html?rand=1234. If your original URL already had a query string (e.g. http://www.a.com/b.html?a=1) then you'd use http://www.a.com/b.h...?a=1&rand=1234. That will force the page to reload because the browser recognizes that could be a different page.. Just remember to use a different random each time.
That's a common problem in a number of programming situations not just limited to LabVIEW. The HTTP protocol has metadata saying how long to keep a cached copy around and also metadata to say if a file is newer than another copy. I'm not sure if your web server isn't sending that data, it's sending the wrong data, or LabVIEW isn't respecting that.
  • Like 2
Hi Mike,
Yeah...it works..thumbup1.gif Yes it does. Thank you very much... worshippy.gif
P.S:
for other junior Labview developers. the '?' symbol could also be followed by ".html"-(for eg: http://abc.com/read.cgi?page=templates/admin_masterconfig.html&Sharon=12)
in that case we will use only '&' symbol like "&random=xxx" not one more '?random=xxx'- it will show an error.oops.gifbiggrin.gif
