Label for dynamic events
Hello all
I work at application sensitive for other application events. Using function 'Register For Events' dynamic register four events from that same VIs with that same indicator name.
Finally I get four events with that same name, but I would like specify different names for them.
Here is diagram:
Is it possible to do that?
regards
Mikrobi
Hey Mikrobi,
You can change the name of the events. The key is to change the name of the refnum that you are passing into the Register for Events primitive. However, if you're using the same subvi to pass that reference out that makes it a little tougher, but still possible.
Derek Lewis
Hey Mikrobi,
Derek Lewis
1545[/snapback]
Yes, it is possible to change the name of refnum, but only at edit mode. I need to set events name at run mode. :(
regards
Mikrobi
Hey Mikrobi,
Derek Lewis
1545[/snapback]
To change the dataname of a wire, use the function Typecast or Variant to Data. On the type input, wire an appropriately named control or constant.
1550[/snapback]
Yes but it is static method, I need to do it from control. Your method base at control or constant with existing name, but I want to set name from control input.
Yes, at runtime.
regards
Mikrobi
Hi Mikrobi,
I'm not entirely sure if I understand what you're trying to accomplish but I believe it sounds like you want each event to occur based on different controls. If this is the case all you need to do is pass the dynamic event refnum into another register for events function. Then pass the refnum of each control you want to associate with that event. From there the event handler should take care of the rest.
Good luck,
Derek Lewis
Yes, at runtime.
regards
Mikrobi
1553[/snapback]
If the event name is not known at edit time, how could you create an event case for it, and put code to handle this unknown event :question:
You can use a type-cast to rename your wire:
post-253-1093519378.jpg?width=400
Didier
:thumbup: thats work :)
For the specific use of casting control refnums, the function "To More Specific Class" is more appropriate here, providing an error when the typecasting is not appropiate for the control class e.g. typecasting a generic control refum (string) to a specific control refnum (numeric).
