JCFC Posted March 3, 2011 Report Posted March 3, 2011 (edited) Hi to all, I have a Laptop with LV 2010 installed and a remote PC without LabVIEW where I install my programs (it acts like a server), it has some inactive programs made with LV 8.2 I have this program: And i made an Executable that runs once (just for testing purposes) I Built an Installer, installed it on both computers and run it Time on laptop: ~23 seconds Time on PC: ~119 seconds (That's right, because the laptop is newer than PC, and I need to execute it every 5 minutes) The problem start here: I inserted the VI inside a Timed Loop as pictured (Dt: 1 s, Discard missed Periods, Maintain phase) And these are the results: Time on laptop: ~22 seconds (like the first one and it executed 4 times at the moment of the screenshot) Time on PC: ~1212 seconds!!! ~20 minutes!!! just one execution on that moment!!!! Replacing the Timed Loop with a While loop with a Wait until ms multiple give this: Almost like the first test. Another test with Timed Loop (Discard missed Periods, Don't maintain phase) took ~20 minutes too. So it has something to do with a Timed Loop on the PC (because the timed Loop on the Laptop doesn't present any problem) and changing the Timed Loop is the answer (maybe) but why? But i can't figure what can be the problem. Any Clue? Edited March 3, 2011 by JCFC Quote
cmh Posted March 7, 2011 Report Posted March 7, 2011 (edited) Hi, A colleague of mine also experienced problems when building exe-files of programs containing timed loops. I too would be interested to hear more about this issue. UPDATE: Googling revealed that this seems to be a problem with hyperthreading. Disabling hyperthreading might help. See, e.g. http://forums.ni.com/t5/LabVIEW/LabVIEW-crashes-in-timed-loops/m-p/369195 Regards Martin Edited March 7, 2011 by cmh Quote
