Snippet?
Pete, what browser are you using?
Currently LabVIEW only supports drag and drop from IE directly into LabVIEW, to use the snippet in another browser you can use a 'IETab' plugin which basically is IE in an activeX frame, or drag the image to your desktop (or another folder) and drag-drop from that location.
ton
oh man,
turns out I needed to drag from IE to desktop then to LabVIEW.
so simple!
(In LabVIEW 2010)
Maybe I am missing something simple -OR- I haven't found the right online resource or post, but..
I can't figure out how to drag and drop a snippet to my block diagram.
I installed the Fetch Snippet files per this document/link:
http://decibel.ni.co...t/docs/DOC-6229
I feel like I am missing out if others are having fun dragging and dropping....
ton
For some reason this never worked for me with Internet Explorer Version 8.0 (7600.16385). But dragging to desktop first fixes this issue.
