Determine Application's Call Stack from SubVI
Hi all,
Is there a way to determine the call stack in LabVIEW, I can't seem to find discussion of it anywhere.
My goal is for a subVI to know the name of his calling VI. I do know that you can access "Callers", but that doesn't tell me who specifically called the subVI.
Thanks!
-Justin Reina
Hello,
Try to use "Call Chain" function located in Programming->Application Control. It will return the array of VIs in a call stack.
Yep, sure can. There is a VI named Call Chain and its in the Application Control Functions Palette.
post-10325-0-77437000-1300259176_thumb.p
If you want a shortcut - OpenG has some great utilities, for example, in the OpenG Application Control Tools Palette:
post-10325-0-25563300-1300259379_thumb.p
Cheers
-JG
  • Like 2
