How to hide seperate tabs of an index card?
Hi!
I like to hide some tabs of an index card depending on a radio button. How
can I enter this hide property on the index card? Or ins't there any
property and I must create a case or an event? :blink:
I try to put my index card into ab event but there is no help for how to connect an index card (my help said no description available :headbang: )
Don't think you can hide individual tabs, but you can disable them. Look for the appropriate property node. You can also hide all the tabs using a right mouse click and selecting the appropriate drop down menu.
As a workaround you could hide all the tabs and display just a string indicator of which is the current TAB above the top left corner.
cheers, Alex
you can access the properties of the individual pages by using the Pages-property
Then by indexing the correct refnum, you're able to hide/show the pages you want.
See attachement for an example.
Greetings from Germany,
VDB
post-397-1094201072.jpg?width=400
VDB
1627[/snapback]
I can't find the proberty PageVIs :wacko:
If I connect thearray index with the proberty node, I get Page, ok, but if I click for the proberties, I can't find PageVis, only page active, page visible....
If I disconnect this I can choosea class ... :lightbulb:
1632[/snapback]
Sarah,
"Page Visible" is the one you need. It's only shortened to "PageVis" in the Property Node.
(right click on the node, Name Format, Long Names)
good luck,
VDB
