Sequence calling sequences in different executions
Roderic
I'm trying to launch different sub-sequences in different executions( I intend them to run in parallel this way I can stop and re-launch a sequence as needed). My problem is the sub-sequences do not seem to execute, I tryed to use a prompt message dialog box, but it doesn't show up... (it works fine if I launch it in the same execution, or new thread)
in the report, I can see the call sequence step is "done"...
How can I configure TestStand to get the intended behavior???
can I launch a sub sequence in parallele mode if my main sequence is in a sequential mode?
Best regards,
Rodéric L'EXACT
Ps: I need them to run in parallel for data acquisition
  • 2 weeks later...
I solved my problem, TestStand uses "MainSequence" as an entry point, when I select "use new execution" I have to select "single pass" as an entry point.
