Panel Printout Resolution is Poor?
I'm in the process of making a VI that can printout a report that show barcodes that the user can use to scan for other purposes. I'm using the VI Invoke Node "Print.Panel To Printer" and for some of the controls it looks like it is printing out in full resolution true type, but for others it is printing using the screen resolution. Attached is a PDF of the problem. You can see it more clearly if you zoom.
Why do you think this is occurring? (I'm using LabVIEW 8.5 if that matters, has this been fixed in a later version?)
Thanks,
Bruce
Barcodes.pdf
