labview & ms access
I've connect my access database with labview by uising the activeX connection (DAOEngine)
This work correctly,but now i need create a sql select...innerjoin query between two table of my DB.
I see the problem is the count byte property of recordset, get one record (reality is more records).
The attached ExtractTable is in LV6.1 :headbang:
Thanks for HelpMe
Bytelab
Download File:post-395-1094465031.llb
  • 1 month later...
Thanks for HelpMe
Bytelab
1654[/snapback]
To get the record count or any count using ADO in combination with a recordset you need to have exclusive access rights to the recordset. Try opening your recordset using "lock optimistic" functionality.
Also have a look at a new database toolkit at www.tm-solutions.nl\eng\
Greetz
