durnek60 Posted April 29, 2011 Report Share Posted April 29, 2011 Hi! I've a Host to Target DMA, that transfers data to the Upper loop. I'm counting the data arrivals and sending the data from upper loop to the lower loop by INNER_FIFO. (After the specified data arrived in the upper loop more data will be transfered to OUTER_LOOP, but it can not be seen on picture.) Placing an INNER_FIFO -> Get Number of elements to Read method in the INNER_WINDOW, I see, the remaining elemens in the fifo is highly increased by the time... Maybe my calculation in the Inner_window loop takes so much time, so the fifo will be full? INNER_FIFO (Target Scoped, Flip-Flops , 10.000 elements) If it is, how can I reduce the calculation Time? Another question, If I have a Target Scoped FIFO with only one Read and Write, shall I set it artbitrate Never? Thank you! (I can not post to NI forum, I got an Unexpected Error all time... ) Link to comment
Please sign in to comment
Sign In Now
