John Lokanis Posted May 4, 2011 Report Posted May 4, 2011 (edited) I am trying to read and write the digital output on an NI9476 cRIO device in an NI9148 cRIO chassis using the shared variable VIs. I want to create a generic driver that can access any cRIO hardware on the network provided I know the IP, module slot and port on the device I am interested in. I created a simple VI to do this. When I run it, I don't get any errors, but it does not appear to control the output I am targeting. Has anyone else done something simular? Is there something simple I am missing? This is the first time I have messed with cRIO. All our current setups use cFP but we are interested in changing to cRIO hardware in the future. Here is my code: thanks for any ideas! -John Edited May 4, 2011 by John Lokanis Quote
TobyD Posted May 5, 2011 Report Posted May 5, 2011 I am trying to read and write the digital output on an NI9476 cRIO device in an NI9148 cRIO chassis using the shared variable VIs. I want to create a generic driver that can access any cRIO hardware on the network provided I know the IP, module slot and port on the device I am interested in. I created a simple VI to do this. When I run it, I don't get any errors, but it does not appear to control the output I am targeting. Has anyone else done something simular? Is there something simple I am missing? This is the first time I have messed with cRIO. All our current setups use cFP but we are interested in changing to cRIO hardware in the future. Here is my code: thanks for any ideas! -John This is off the top of my head as I don't have LV in front of me, but I think your URL might need to be set to ni.var.io:// instead of ni.var.psp:// when configuring outputs. -Toby Quote
John Lokanis Posted May 5, 2011 Author Report Posted May 5, 2011 ni.var.io allows forcing outputs via property nodes but does not allow them to be read back. The shared variable VI reject a URL that uses ni.var.io. They accept ni.var.psp. Also, you cannot browse for anything under ni.var.io. Looks like it is time to call in the big guns at NI. BTW: I was able to get it to work somewhat by adding a 300ms delay after the write and adding a delay before the close. But, the value does not 'stick' in the DO. Once the close is called, the value reverts to false (off). If I remove the close, the value reverts when the VI stops. No idea why it wold 'latch' the value. Quote
