Fredxxx Posted May 10, 2011 Report Posted May 10, 2011 Hey all! I got a Problem here and hope perhaps you can help me. I have two VIs: a Main.Vi that constantly produces data and a webmethod.vi (Block Diagram attached), which calls for that data and publish it to the web. I have already set up a WebServer in the ProjectExplorer, where i added the webmethod VI to the Sourcefilelist. This should work fine. The problem is, that i can not retrieve the data from the Main.vi. Precisely, I don´t get the Ref of the Main.Vi, when I run the Webmethod.vi through the URL. I guess, that the node "Open VI Reference" doesn´t work with Web Services. Is that so? What can i do do get this webmethod.vi to work?? Thanks a LOT, Greetz Fred Quote
ned Posted May 10, 2011 Report Posted May 10, 2011 The Web Services VI runs in a different application instance than your main vi, which is why your open VI reference isn't working as expected. There was some discussion of this here. If you get a reference to it in the right instance, you should be able to get it working. Quote
Fredxxx Posted May 19, 2011 Author Report Posted May 19, 2011 On 5/10/2011 at 3:20 PM, ned said: The Web Services VI runs in a different application instance than your main vi, which is why your open VI reference isn't working as expected. There was some discussion of this here. If you get a reference to it in the right instance, you should be able to get it working. Hey, thanks for the advise. I gonna have a look! Quote
