IvoOvermars Posted May 26, 2011 Report Share Posted May 26, 2011 Hello all, For my work I'm trying to convert the example simulation "Simulation - Tank level.vi" to a real testrig. The simulation does exactly what we want students to do with the P, PI and PID control theory they have had. My problem is that I do not have a any experience with labview, or any other programming language. So I'm learning as I go along with this project. In my estimation this simulation I have to insert my DAQ's somewhere to get the level measurement and valve control. But I have no idea where they go, what they should replace or how to connect them to the PID node. Any help, pointers examples would be appricated Kind regards, Ivo Overmars My setup consists of Labview 2010 sp1 PID&Fuzzy logic toolkit NI9203 NI9265 PID trial 16 Folder.zip Tank Level Example.vi Link to comment
SuperS_5 Posted May 26, 2011 Report Share Posted May 26, 2011 Hi, I have been looking at your VI. I would completely remove the "plant.vi" simulator. That is where your DAQ calls could go. (That's the simple approach) The LabVIEW example finder will help you with the DAQ calls. You need to output your pid value. and get the level. I wouldn't personally use this single loop approach because it is not scalable, and would not be responsive enough if the output valves have to be driven more slowly. There are a lot of examples in LabVIEW, and on Google to get you started there. Link to comment
IvoOvermars Posted May 30, 2011 Author Report Share Posted May 30, 2011 Thank you!! I got it working now. The problem was indeed that I had to set the 0-20mA as limits in the PID. Hi, I have been looking at your VI. I would completely remove the "plant.vi" simulator. That is where your DAQ calls could go. (That's the simple approach) The LabVIEW example finder will help you with the DAQ calls. You need to output your pid value. and get the level. I wouldn't personally use this single loop approach because it is not scalable, and would not be responsive enough if the output valves have to be driven more slowly. There are a lot of examples in LabVIEW, and on Google to get you started there. Link to comment
IvoOvermars Posted May 31, 2011 Author Report Share Posted May 31, 2011 Another question about this VI. The way I've wired this together my output seems to be either 0 or 20mA, nothing in between. Does anyone have any suggestions? All in One probeersel pid 17.vi Link to comment
ned Posted May 31, 2011 Report Share Posted May 31, 2011 Another question about this VI. The way I've wired this together my output seems to be either 0 or 20mA, nothing in between. Does anyone have any suggestions? Wiring looks OK. Have you tuned the PID at all? What is the possible input range? If your input is a level from 0-100 and your output is only 0.004 to 0.02 A, you'll need very small gains in order to get the response you want. For example, say your setpoint is 75 and your level is 70, with the proportional gain set to 2.5 (as you have on the front panel) your output just from the Proportional component will be 2.5 * (75-70) = 12.5, which is several orders of magnitude larger than your possible 0.016 A range. You could also solve part of the problem by setting your PID output range to be in mA rather than A, and dividing by 1000 before setting the output on the DAQ device. Link to comment
IvoOvermars Posted June 9, 2011 Author Report Share Posted June 9, 2011 Wiring looks OK. Have you tuned the PID at all? What is the possible input range? If your input is a level from 0-100 and your output is only 0.004 to 0.02 A, you'll need very small gains in order to get the response you want. For example, say your setpoint is 75 and your level is 70, with the proportional gain set to 2.5 (as you have on the front panel) your output just from the Proportional component will be 2.5 * (75-70) = 12.5, which is several orders of magnitude larger than your possible 0.016 A range. You could also solve part of the problem by setting your PID output range to be in mA rather than A, and dividing by 1000 before setting the output on the DAQ device. Thank you. With the tips you gave I got it to work perfectly. I made the mistake to use the values given to me whithout questioning them, since I have an analytical chemistry background and not chemical engineering. I tuned the device now using the Ziegler and Nichols method. Link to comment
Please sign in to comment
Sign In Now
