Karlo Posted May 31, 2011 Report Posted May 31, 2011 (edited) Data.zipSorry for the earlier post. I am quite new here. Anyway, here's problem. I need to plot my data from a set of text files and I want to present it like this Cone_mesh.jpg However, when I try to plot it, what I get is this : Actual_plot.jpg Edited May 31, 2011 by Karlo Quote
Grampa_of_Oliva_n_Eden Posted May 31, 2011 Report Posted May 31, 2011 Data.zipSorry for the earlier post. I am quite new here. Anyway, here's problem. I need to plot my data from a set of text files and I want to present it like this Cone_mesh.jpg However, when I try to plot it, what I get is this : Actual_plot.jpg Choose plot style >>> Lines What you have now is level lines. Ben Quote
Karlo Posted June 1, 2011 Author Report Posted June 1, 2011 Wow, that was fast Thanks a lot!!! Choose plot style >>> Lines What you have now is level lines. Ben Quote
Karlo Posted June 2, 2011 Author Report Posted June 2, 2011 Wow, that was fast Thanks a lot!!! I have another problem. Is there a way to adjust the Z-axis? I was able to plot my mesh but the Z-axis is not uniform with each plot. Is there a way to programmatically control Z-axis. Thanks again for the help. Quote
Grampa_of_Oliva_n_Eden Posted June 2, 2011 Report Posted June 2, 2011 I have another problem. Is there a way to adjust the Z-axis? I was able to plot my mesh but the Z-axis is not uniform with each plot. Is there a way to programmatically control Z-axis. Thanks again for the help. Z Axis scale range. See this thread on the Dark-Side were I posted a worse case tutoial. http://forums.ni.com/t5/LabVIEW/Multiple-polar-plots-into-a-3d-plot/m-p/270676#M144155 Ben 1 Quote
Karlo Posted June 3, 2011 Author Report Posted June 3, 2011 Z Axis scale range. See this thread on the Dark-Side were I posted a worse case tutoial. http://forums.ni.com.../270676#M144155 Ben Thanks a lot!!! The information here is of great help! Quote
Grampa_of_Oliva_n_Eden Posted June 3, 2011 Report Posted June 3, 2011 Thanks a lot!!! The information here is of great help! Glad it helped. That one example has been used to answer dozens of 3D questions. Take care, Ben Quote
