Hi, I want to build a commercial product with the OpenG tool which is LGPL licensed.
Does LGPL mean that I can use the builder while I won't have to make my own code open?
Is it the best free builder toolbox available?
Thanks.
I suggest you do a search here, as there should be some references to how to build applications which comply with the LGPL license using the OpenG builder.
In any case, I thought that all of the OpenG packages were moved to the BSD license quite some time ago, partly to avoid this issue. Which package are you using? Can you update it to a newer version?
