Multiple EXE installer - double files in data directory
Hello guys,
I run into an error similar to this post (actually the same, but I don't like the answer :rolleyes: and it's old).
I'm trying to change an build specification for an installer, which contains multiple exe- files with the same target directory. (LabVIEW 8.6.1f1)
post-17453-0-89718800-1307618646_thumb.j
Some of the exe files use the same *.dll file (lvanlys.dll) which is automatically included by the application builder.
I've already used the same project a couple of times and LabVIEW has never complained about anything. Just now I've added
another application and nothing works.
What am I doing wrong?
Is there a way to tell LabVIEW everything is OK? (Since it's the same file, so what)
I don't want to seperate the exe- files in own directories.
Greetings, LogMAN
I was reading this post and thinking, "Yeah, that is really annoying! I can't believe I haven't complained about this before." Turns out I have. :-)
I'm still using the same lame method of dragging all the files over individually. So far no problems have occured, other than it makes what should be a simple process much more complicated.
Does anyone know if this still a problem in versions later than 8.6?
