kosist Posted June 13, 2011 Report Posted June 13, 2011 Hi everyone! I've got one more question to you. I have to write and send in string zero bit - in Delphi, for example, it is Chr(0). But how should I have write zero bit in LabVIEW? I'm looking forward for your help! Quote
mje Posted June 13, 2011 Report Posted June 13, 2011 Drop a string constant onto the diagram and right click it, then select the '\' Codes Display option. You can create a null/zero bit by typing \00: You can also right click and select Display Style from the Visible Items menu to indicate what style the string is being displayed in. Quote
