How to create yoour own pop-menu on controls
kalyanramu
Hi all,
Does anyone how we can create our pop-menus for controls.
For example,
If I right click on a graph, I want to add my own label in the pop-menu like "Copy Data between cursors".
How can I achieve this one.
Any help on this would be greatly appreciated.
Thanks,
Kalyan
Unfortunately this is a big leak of LV - at least until LV7.0, for 7.1 I don't know. I also often missed them, or at least the ability to disable parts of the standard pop-up menu.
You can disable the ability of pop-up menu for the whole vi (vi-properties-> appearance-> customize-> Allow run-time shortcut menus), that's all.
A workaround would be to disable them and show a dialog-vi at mouse position on a right-mouse-button click event. Seems complicated:
1. create a sub-vi (as dialog) and design it the way that just either a table or text ring is visible (no border, menus,...)
2. disable on your top-vi the run-time shortcut menus
3. put over your graph a transparent control that allows the event: right-mouse-button click
4. react on this event and show the dialog-subvi.
5. read the mouse position and reposition your dialog-subvi.
I thougth there was once an article in the LTR, but since I don't own the full collection I didn't found it. If anybody has more info?
Didier
Just because I'm feeling giving today.
Heres a great place to start from.
1773[/snapback]
hi...
I try to download ur attachment..but unfortunately i'm using LV7.0..I feel so dissapointed.Can u give me another axample which are using LV7.0?I really appreciate ur help...
Regards,
Roxe ;)
