Format Dialogue String
I want to format the dialog string, ie change them to bold, justify etc
How can I do this?
Make your own dialog boxes. The ones NI supplies aren't very flexible.
My dialog boxes are usually a text box with a button or two all on a vi with a very small front panel. Then you have more control over the text format. You can also code other features, such as setting up a timer input so the dialog box will go away after a number of seconds with no response, or beeping to alert the user a dialog box has appeared.
