Fredxxx Posted July 13, 2011 Report Posted July 13, 2011 Hey everybody, i have a little problem here. On my block diagram i have a numeric control terminal . I want to drop a VI Server reference and a digital numeric Refnum form my existing control on the block diagram. I already tested around with the "New VI Object" Node, but figured out, that it`s not that easy Thanks in advance. Fred Quote
Yair Posted July 13, 2011 Report Posted July 13, 2011 For the reference, use the terminal's reference to get a reference to its control (available as a property), then call the Create Reference method on that control. For the constant, you should be able to use the New VI Object primitive to drop a Class Specifier Constant, which you can then configure using its Type property, which accepts the name of the class (although I don't think that will get you the strict reference which you seem to want). The class is in GObject>Constant>Refnum. Quote
