Daklu Posted July 21, 2011 Report Posted July 21, 2011 I've attempted TDD in Labview a few times over the years and believe it would be a huge benefit... if I could figure out how to do it effectively. There's one issue I keep running into--namely, doing TDD in most languages entails writing the test code before writing any of the functional code that will be tested. Problem is... we can't do that in Labview. I can't drop a non-existent method for a non-existent class on the test method's block diagram. So I have to create the class and method stub before I can make any significant progress on my test, which disrupts the TDD process and eliminates at least some of the advantages of doing TDD in the first place. Is there anyone who feels like they have successfully implemented a TDD process for LV development, and if so, can you share some of the strategies you use to work around our inability to code to non-existent classes and methods? Quote
Falevoz Y. Posted July 21, 2011 Report Posted July 21, 2011 (edited) Hi, I know you can edit the test cases in a text editor or in Excel. Maybe you can write your tests before coding this way... Or create empty VIs and write your tests before coding them... BR Yann Edited July 21, 2011 by Falevoz Y. Quote
crelf Posted July 21, 2011 Report Posted July 21, 2011 If you use the LabVIEW Unit Test Toolkit, the test definitions and vectors are text files - you could definately use those before the code is written. Quote
Daklu Posted July 21, 2011 Author Report Posted July 21, 2011 Bad me. I neglected to mention I've been using JKI's VI Tester. I've tried NI's UTF but had some issues with being unable to remove tests from the project and it annoyed me. On 7/21/2011 at 7:08 AM, Falevoz Y. said: Or create empty VIs and write your tests before coding them... Yeah, that's what I've been doing. But before I create the vi I have to create the class, and sometimes the method will return other classes, which means I have to go create them too. I think there's a real benefit to focusing on high level behavior by writing tests first. What ends up happening is I have to stub out the entire design before I'm able to write any tests, and that drags me into thinking about implementation instead of high level behavior. One of the ideas of TDD is to create a test, watch it fail, then implement enough code to make the test pass. I tried creating a generic test stub class and methods to use as filler while creating tests. That didn't work so well. It requires too much temporary code (to prevent compiler errors) that gets removed when the implementation is ready to be tested. I also don't really like the idea of editing the test to replace the generic stubs with the real code. Unfortunately I don't really see a good solution here. I suppose dynamically calling the code being tested would work, but that doesn't sound like a very good idea. I guess I'll have to keep creating stubs of my production code and try not to think about implementation. Quote
crelf Posted July 21, 2011 Report Posted July 21, 2011 On 7/21/2011 at 5:07 PM, Daklu said: Bad me. I neglected to mention I've been using JKI's VI Tester. I've tried NI's UTF but had some issues with being unable to remove tests from the project and it annoyed me. Yeah, that's a nasty bug. Thankfully, the lvproj file is XML, so you can delete them in the file. Quote
Daklu Posted July 23, 2011 Author Report Posted July 23, 2011 On 7/21/2011 at 6:01 PM, crelf said: Yeah, that's a nasty bug. Thankfully, the lvproj file is XML, so you can delete them in the file. If you remember to do it before opening the project. (I usually didn't...) I get the impression VIE uses the UTF. In your opinion, does the UTF work well for testing object oriented code? I get the feeling UTF is better suited to testing procedural-based vis and JKI's VIT is better for testing objects. (Seems to me the NI and JKI should swap names of their unit testing tools. ) Quote
jgcode Posted July 23, 2011 Report Posted July 23, 2011 I reported this bug: http://forums.ni.com/t5/LabVIEW/Unit-Test-Framework-Crashing-LabVIEW-Project/m-p/1110768 And got CAR 220428 for the icon issue but NI could not replicate the crashing issue when removing a test from the project file. It is the same issue you have? Did anyone get a CAR they can post? This bug is very annoying. Quote
Daklu Posted July 23, 2011 Author Report Posted July 23, 2011 On 7/23/2011 at 11:15 PM, jgcode said: It is the same issue you have? Did anyone get a CAR they can post? Sounds related. I posted there issue here but didn't get a CAR. Quote
jgcode Posted July 24, 2011 Report Posted July 24, 2011 I just posted in my NI thread a link to your post. Let's see if we can get someone to revisit this issue, track it down and get it fixed Quote
jgcode Posted August 4, 2011 Report Posted August 4, 2011 On 7/24/2011 at 12:48 PM, jgcode said: I just posted in my NI thread a link to your post. Let's see if we can get someone to revisit this issue, track it down and get it fixed Sorry for the highjacking... but just a note to say that it seems this issue has gone away in LabVIEW 2011 which is good news. And whether others can confirm this. Quote
