jzoller Posted August 8, 2011 Report Posted August 8, 2011 Inspired by this idea, these are just a few, one-day-of-coding functions that implement a simple, regex based markup for string controls. For those not familiar with it, markup allows inline text to modify the displayed properties of the text. For instance, **bold** becomes bold, _italics_ becomes italics, etc. The code currently supports: Bold Italic Underline Colors (in #XXXXXX format) Text sizes (verysmall, small, large, verylarge) Strikethrough Some font setting Of course, it's still limited by the string control capabilities (no hyperlinks, no superscripts, no embedded lists). If people think it's worthwhile, I'll develop it into a somewhat more complete solution (or, of course, they can!). An X-control that supports it seems like an obvious extension, but I'm open to ideas. Note: this was developed in LV2011, and back-ported to LV2009. If you spot a problem with it, please notify me. Use: open and run LVMark_TestString.vi for a demonstration. Thanks, Joe Z. LVMark2009.zip 2 Quote
Ton Plomp Posted August 8, 2011 Report Posted August 8, 2011 Based on the title, is this meant to be MarkDown compatible? That would be very nice! Ton 1 Quote
jzoller Posted August 8, 2011 Author Report Posted August 8, 2011 Based on the title, is this meant to be MarkDown compatible? That would be very nice! Ton I think it could be (and I would like it to be!), but there are some fundamental differences in how they work. For instance, Markdown doesn't support underlining, and focuses pretty heavily on linking. I would like to end up closer to the Markdown spec than it is now, but there's a good bit of work yet to go. Joe Z. Quote
asbo Posted August 8, 2011 Report Posted August 8, 2011 In LV2009 (Win7 SP1 32-bit), it seems that small and very small text do not work. I don't think your code is to blame, I manually cranked it down to 2pt Courier and it didn't change size whatsoever. I think MarkDown support would be pretty cool too, and BBCode and CSS while you're at it! Quote
Wouter Posted August 9, 2011 Report Posted August 9, 2011 (edited) Hmmm I just checked it out. It looks good but I don't really like the codes... such as **bold** etc... rather would have [b]bold[/b] , with a clear opening and closing bracket but that can proberbly be changed easily. Also I would have implemented differently because now you loop threw the whole text each time for every style element and afterwards applying the style, you can do all of this in just 1 loop. Edited August 9, 2011 by Wouter Quote
Ton Plomp Posted February 8, 2013 Report Posted February 8, 2013 If you like Markdown, I have created a library to use the LabVIEW report toolkit. See at Bitbucket Ton 2 Quote
hooovahh Posted July 13 Report Posted July 13 I know this post is ancient by internet standards, but I've been using LVMark off and on for years now. I recently posted a Hooovahh String package here on VIPM.IO. I plan on making a video demonstrating features of that package including LVMark some day. The LVMark code is mostly unchanged from the version posted here, just some comments and VIA_Ignore tags mostly. I do think there are places where performance could be better, but I've only ever used it on relatively small strings. There seems to be other LabVIEW Markdown libraries, like the one Ton linked to (but links seem to be dead), and a QControl here that has similar functionality. I do like the simplicity of LVMark. Quote
ShaunR Posted July 14 Report Posted July 14 23 hours ago, hooovahh said: I know this post is ancient by internet standards, but I've been using LVMark off and on for years now. I recently posted a Hooovahh String package here on VIPM.IO. I plan on making a video demonstrating features of that package including LVMark some day. The LVMark code is mostly unchanged from the version posted here, just some comments and VIA_Ignore tags mostly. I do think there are places where performance could be better, but I've only ever used it on relatively small strings. There seems to be other LabVIEW Markdown libraries, like the one Ton linked to (but links seem to be dead), and a QControl here that has similar functionality. I do like the simplicity of LVMark. I wrote a markup string xcontrol. I really should look at it again because I don't think the mouse-over for links work properly on Windows 11. Quote
