HP4194A Status byte check with labview 6, HOW?
sephi23
Try the status function.
1950[/snapback]
thanks for your answer, the problem is, i have tried this function, too. and there are some GPIB command, which used to check the status. like: *STB? oder *ESR? but the 4194a doenst understand all the commands...(strang isnt it?) like: if I use STB? (with gpib write)
OR RST, and it does really what the command says. but if i use ESR? or ESE the 4194a just told me: "undefined symbol" or "commandsyntax error"(it shows me "commandsyntax error" every time, if i put a * before the commands)
ths Status Byte should be 8-bit long. but the status answer form gpib write or Stat function returens always 16 Bit..... i have tried the whole time yestoday afternoon and nothing happens :headbang:
please...help me :worship:
