Windows message box
aah31
I'm sorry, but your question is not clear. Are you referring to using the Call Library Function Node? And what "windows message box's [sIC]" are you referring to? Are you asking how to use the Call Library Function Node? If so, there is an extensive example that ships with LabVIEW (Help -> Find Examples). Just search for "DLL".
Please provide a better explanation of what you are trying to do.
I think he wants to know which DLL to call, the function name and its parameters to pop a standard Windows messagebox, with the standard (?), /!\ or (X) icons and stuff.
OK, that makes sense. In that case, attached is a simple example that replicates the last example on that page.
MessageBox Example.vi
