dprylows Posted August 29, 2011 Report Posted August 29, 2011 (edited) Hi, I have several vis that have strip charts with 200k point chart histories. These vis run fine with Labview 2010, with 2011 the vis crash with a memory error. If I reset the chart history to the default 1024 points, the vis will run. What could be causing this? I've tried deleting the charts and then rebuilding them. That didn't change anything. regards dp Edited August 29, 2011 by dprylows Quote
Tim_S Posted August 29, 2011 Report Posted August 29, 2011 Have you tried rebooting (has worked for me when some memory issues occur)? Is this something you can reproduce? If so, I'd recommend calling NI as they will want to look at your code. Tim Quote
dprylows Posted August 29, 2011 Author Report Posted August 29, 2011 I have rebooted. I can reproduce the issue on two different machines ( winxp, win7 ). I have sent a code sample to NI. They can reproduce the problem and are looking into it, but no time table for a resolution. I was just wondering if anyone else has seen this and knows of a solution. As it stands, I can't use 2011. Thanks dp Quote
