LV User Posted August 31, 2011 Report Posted August 31, 2011 I have a new requirement where I have 16 UUT to be tested in parallel. All the DUTs have their own separate input /output resources from the PXI. All the tests are same all the UUTs. I need to write a single program and be able to run for all the 16 UUTs in parallel. What is the best way to develop the test program. Quote
crelf Posted August 31, 2011 Report Posted August 31, 2011 Use the right tool for the job: www.ni.com/teststand Quote
LV User Posted August 31, 2011 Author Report Posted August 31, 2011 Yes I am using Teststand, Is there any white paper that explains how this can be accomplished in Teststand? Quote
asbo Posted August 31, 2011 Report Posted August 31, 2011 Here's a good starting point: http://zone.ni.com/devzone/cda/tut/p/id/7170 2 Quote
crelf Posted August 31, 2011 Report Posted August 31, 2011 That's a good link from asbo - since you access your UUTs through separate input/output resources, then you'll want the parallel process model. Quote
Roderic Posted September 3, 2011 Report Posted September 3, 2011 I agree with crelf on the parallel process model. There are examples shipped with TestStand in the example directory you should have a look at them. Quote
