pzucchel Posted September 28, 2004 Report Posted September 28, 2004 Hi, i am currently facing the following problem: i have coordinates of points lying on a 2D plane, the coordinates are collected in two different reference frames which are rotated by an angle which is not exactly known. i would like to extract the angle by minimization of a function built on the basis of the point coordinates and the rotation parameter, to be minimized with respect to the rotation parameter (simple chi2 built on the metric distance). being a non-linear function in the rotation angle parameter, i feel i should use the non-linear levenberg Marquardt fit routines (under LV 7.1 professional). However, these function require a set of 1D independent variables, while i have a 2D independent variable set. to complicate, even the translation beween the two frames is not exactly known, so the parameter space is three dimensional (but this should not be a problem in principle). Anybody that has an idea if i could retrieve packages/examples that do the job, or if there are ways to cheat the fitting routine? i wonder if the function should have derivatives in the independent variables set. thanks indeed, Best Regards Piero Zucchelli Quote
