fabian Posted September 8, 2011 Report Posted September 8, 2011 Hi there! I've got a problem with connecting to a OPC-Server in LV2011 64Bit. LabVIEW shows an "Class not Registered"- Error. (see Attachment) I try to connect to a CoDeSys OPC server, but it also happens when i try to connect to the NI Demo OPC server. I used the LabVIEW OPC Example (Browse To OPC Item.vi) to test the connection. With LV2011 32Bit everything seems to be ok, so i think the services should be correctly registered? Any ideas? thx fabian Quote
