dynamically created a microsoft access 2007 database using labview
lyfforever
  • 11 months later...
Where is the Access_Application active X control located at? I can't seem to find it when I try to insert an active x object control....?
Nevermind sorry I was overlooking it!
First sanity check: do you have any of Office installed? I found the type library under "Microsoft Access 14.0 Object Library Version 9.0" and am running Office 2010 Pro Plus.
Second sanity check: does the snippet about not work for you? I drop it and it opens Access on my machine.
