Reset the counts
You can reset the counter by subtracting an 'offset' count-at the time the reset button is pressed - read the store the current counter value - then subtract that values from all following counter readings.
See image of code.
post-37-1097038090.jpg?width=400
Yes, you can - but you may loose counts during the reset of the counter. My suggested method - you don't.
It depends upon your needs.
2147[/snapback]
Thanks JackHamilton :worship:
You have given me a helpful suggestion.
Thanks again.
