crichter Posted October 8, 2011 Report Posted October 8, 2011 I have graphs of (X,Y) cordinates (5, 0.19), (10, 0.38) & (20,0.78) respectively. In my VI labeled AA, the horizontal cursor tracks perfectly from 5 to 10 and not so well from 10 to 20. This is just as one would expect, since the slope from 10 to 20 has changed slightly. In vi labeled AB, I have made the code calculate the new slope and would expect correct tracking from 10 to 20. I was only able to achieve tracking by including a 0.4848 offset and even then it is not exact. A 0.38 offset might be understandable, but at present I cannot explain the error. I wish to understand this so that I can increase the complexity of my graphs and then experiment with "in range and co-erce". Any guidance would be much appreciated. graph 3 points AA.vi graph 3 points AB.vi Quote
Ravi Beniwal Posted October 8, 2011 Report Posted October 8, 2011 Is there a reason why you want to calculate the cursor position and make it follow the plot instead of just letting the cursor snap to the plot? Quote
crichter Posted October 10, 2011 Author Report Posted October 10, 2011 That is a fair question Ravi. I wish view to the Y value at various values of X. Before my attempt to control the horizontal cursor, I could simply type my X value into the cursor legend and the the vertical cursor would snap to that value (e.g. 14.4). I would then have to drag the horizontal cursor to the intersection of the trace and the vertical cursor. If I choose "snap to plot" from cursor properties, both cursors will only snap to values I have put into an array. Quote
Ravi Beniwal Posted October 10, 2011 Report Posted October 10, 2011 OK, that makes sense. I changed your code; now (I think) it does exactly what you are looking for. Cursor Traces Plot.vi Quote
crichter Posted October 12, 2011 Author Report Posted October 12, 2011 Thanks for digging deeper for me Ravi. Unfortunately I cannot view the changes, as I only have version 7.0 Quote
Ravi Beniwal Posted December 20, 2011 Report Posted December 20, 2011 Sorry for the delayed response. LabVIEW 8.0 is about as far back as I can go. I've attached the file again saved in 8.0. Cursor Traces Plot.vi Can someone with LabVIEW 8.x please save this VI in 7.0? Quote
