How to change the waveform graph from time domain to frequency domain?
Is the problem just the label? You have to type that in yourself. If it's not showing a waveform that looks like a spectrum, then you have a wiring problem and you should post your VI.
Thanks for your replies.
well i got the desired frequency domain waveform using the FFTvi from the signal processing>>waveform measurements palette.
But when i use the FFT vi from the signal processing>>Transforms palette i am not able to get the similar waveform.
kindly have a look at the attached VI and correct me.
Thanks
upload.viFetching info...
