move contents of one diagram to another
jcarmody
I want to be able to move the contents of a frame in an Event structure to a frame in a Case structure. I've only been able to move them individually, but I want to accomplish this without losing the wiring. Is it possible to do this in one move, or will I need to move and then rewire them?
What if you enclosed the contents with another frame (say a sequence), then moved that. The Scripting Tools have some functions that might help, from which this clip was extracted:
Does that make it easier to do what you want?
Yes, but I couldn't get it to work with a Sequence structure. It worked fine with a Diagram Disable, though.
Thank you.
I seem to recall making it work with a Stacked Sequence (only time I've used that!) but not a Flat Sequence. But a Diagram Disable is just as good, and you can easily remove the structure again after rewiring the connections.
