jpo Posted December 1, 2011 Report Posted December 1, 2011 Hi My application allows the user to change the number of input channels that a chart displays during runtime. When the number of channels vary the X Scale range values reset to zero for the chart. Is there a way I can stop this? I have include a simple demo program showing this issue. When the var number of channels is changed the X scale of Variable Channel Chart is reset. Thanks John ChartDemo.vi Quote
todd Posted December 1, 2011 Report Posted December 1, 2011 This isn't completely correct, but it doesn't clear the history: ChartDemo_1.vi Quote
jpo Posted December 1, 2011 Author Report Posted December 1, 2011 Thanks for the insight. In my version, I display multiple points per channel per loop. Application records 120 channels at 2048 samp/sec so display every point is not possible. When I wire up the output of the array subset vi which is a 2 dimensional array, it will give me an error. Is there a work around? Do you know why this does this happens? Thanks John Quote
Jordan Kuehn Posted December 2, 2011 Report Posted December 2, 2011 One suggestion (if it's purely UI related) would be to move to LV2011 and display the visibility checkboxes. Quote
